[HELP] P38 engine swap to Toyota LandCruiser
#31
OK, ive got a disco with a 4.6 and ive also got a landcruiser with a turbo 4.2D. Im interested in dropping the rangie 4.6 into the cruiser so whoever you get your bellhousing addapter off, let me know cos i want one!
Also if you want a few tips on beefing up the power and economy of your 4.2D ive been playing around with mine for years. Ive got about 21-23pound running through a garrett turbo at about 3100revs and increased the fuel and its VERY touchy but i can explain it if you want. all in all im getting about an extra 50-60Ks more out of a tank and i run 35inch tyres and it will fry them in third gear going up hill on the asphalt. (not bad for a diesel. lol)
also i suggest using a motec e48 ems, just a suggestion.
Let me know how you go.
#32
why I'm using Toyota's engine because Toyota is well known for trouble free motor with cheap and lots of spareparts.
BMW Diesel engine is not as tough as Toyota's engine, if I want to swap, I want to swap with more "trouble free" engine (if it runs
) but now I have to deal with this mess because I haven't done any research first ![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
The BMW Diesel in the Range Rover is total failure here! Fact!
Toyota 6 Zyl. Diesel will fit with gearbox and transfer from the VX
just change brackets and Propshaft . But note!! all these are really specialised jobs and make mainly sense were petrol fuel for example is too bad or not available.
also note!! the 4.2 toyota takes a lot off diesel. about 15l/100km in a P38
#33
If I were you I would stop right now or you will end up re mortgaging your home and you will never even have a vehicle to drive.
Sorry to be a doom merchant here. I wanted to do something similar quite some time ago with my late father's P38/BMW diesel.(Not Bombproof at all) Went into it at length. The problem is that the ECU has total control of everything on the vehicle not just the engine and gear box. If you are the equivilent of a rocket scientist and are a prof computer reprogrammer and feel confident you might get the interior light to come on !!! But that's about it!! Save yourself some money and refit a 5.0ltr engine from RPi or JE Engineering. Straight fit, key in and off you go. Honestly you are opening a can of worms and I am normally a positive thinker. Good luck !!!!
#34
